Sekadar sharing, dan mohon ditambahin, sebagai tips dan trik,.....
Setting PAR Reflex dan G3-------------------------------------------------------------------
Autos
Tuk setting auto rotation di G3,5
Cari Parasitic Drag Factor - makin kecil, makin besar energi blade tuk auto
Tuk setting auto rotation di Reflex
Cari Rotor Moment Inertia - makin besar, makin besar pula energi blade
CG - Center of Gravity
CG di Reflex ada kesalahan arti pada pesawat
di heli, Distance of CG in front of rotor head - benar artinya
di pesawat, Distance of CG behind profile nose - bukan berarti jarak CG ke belakang
dihitung dari "hidung pesawat" / prop/eng, tetapi dibelakang Leading Edge,.....
Jadi seharusnya adalah
"Distance of CG behind of Leading Edge",............
(sekitar 25% dari wing chord - tuk regular/sport flying,
30-40% tuk 3D/Hover Plane, dan 5-10% tuk Glider)
Weather Setting tuk G3,5
Wind and Weather Setting
Global wind:
Direction 0, Velocity 0, Variation 100, Gust 21 (adjust speed/direction in sim with Pgup/Pgdn button)
Thermal;
therm pattern 5, therm strenght 0, sink pattern 0, Cyclon strenght 5, convective high 1000
Turbulance;
Turb height 60, turb strenght 15, micro turb 40
Haze;
up to you, since this is just visual par only, not physics.
SHARING INFO; PAR setting XTR dan G3
Moderator: DeVIN
- DeVIN
- Master Sergeant
- DeVIN
- Master Sergeant
Raptor 50 versi realistik di runryder
100
100
100
100
2
1
1
1
0
0
3.5
1.35
12
0.1
0.1
0.2
0.06
0.2
0.1
0
0
60
40
6000
5
40
2000
2
100
0.38
0.29
0.25
0.2
0.002
0.005
1.32
14450
8.5
95
1.1
10
15
4
0.85
95
1
0.4
0
0
0
10
-10
-8
1980
0.058
0.15
0.1
0.01
1
1
0
0.28
8250
0.03
1
2.3
0
0
20
-15
0.385
0.005
0.06
1
35
100
Thunder Tiger\Raptor 50V2 real
Thunder Tiger\raptor30-hq
VORSPUR=0
CG_FW_Y=1001
CG_FW_Z=1001
VERSION=5
EXP_NICK=-15
EXP_ROLL=-15
EXP_GIER=0
Copy dan paste,............ ke PAR raptor anda.
Salam.
100
100
100
100
2
1
1
1
0
0
3.5
1.35
12
0.1
0.1
0.2
0.06
0.2
0.1
0
0
60
40
6000
5
40
2000
2
100
0.38
0.29
0.25
0.2
0.002
0.005
1.32
14450
8.5
95
1.1
10
15
4
0.85
95
1
0.4
0
0
0
10
-10
-8
1980
0.058
0.15
0.1
0.01
1
1
0
0.28
8250
0.03
1
2.3
0
0
20
-15
0.385
0.005
0.06
1
35
100
VORSPUR=0
CG_FW_Y=1001
CG_FW_Z=1001
VERSION=5
EXP_NICK=-15
EXP_ROLL=-15
EXP_GIER=0
Salam.
- DeVIN
- Master Sergeant
