@oom Devin
oom mau tanya & bantuannya kalo mau donlod video tutorialnya simulator link-nya tolong diinfoin dong oom...
hehehe...maklum rada2 gaptek ney oom
makasih banget
video tutor
Moderator: DeVIN
- rudyWing
Re: video tutor
Coba buka www.youtube.com, masukkan kata kunci mis: "RC Simulator landing"... donlotnya pake www.keepvid.com dgn memasukkan address youtubenya... smoga berhasil
- DeVIN
- Master Sergeant
Re: video tutor
Masing2 simulator ada video-nya yang biasanya bisa didonlot dan diputar dari sim-nya sendiri,...tuk phoenix v 2 kan ada di halaman downloadnya? http://www.phoenix-sim.com/downloads.htm
dengan petunjuk
Manually updating
Here you can find the manual download links if you are unable to use the Automatic Updates system from within Phoenix version 2.0.
If possible you should always use the Automatic Updates system to ensure best results.
To manually update, please do the following:
• Ensure you have the latest release version of Phoenix from the downloads section above.
• Download the files you wish to update into your "My Documents/PhoenixRC/Downloaded Updates" folder.
• Make sure Phoenix is not running.
• Open your Phoenix installation folder (usually "c:/program files/phoenixRC").
• Double-click the application named "PhoenixUpdateInstaller.exe".
• You may be prompted to Allow this program to run by Windows. Click "Allow".
• You will then be asked if you wish to update manually. Click "Yes".
• The updates you downloaded will then be installed, and Phoenix will start with the new updates applied.
Salam.
dengan petunjuk
Manually updating
Salam.
- BERTHIE FLYER
- Master Sergeant
Re: video tutor
wah bang devin memang sepesial phoenix rcfs nih.... Btw bang devin ga pernah terbang ya? Kita ga prnh ketemuan di ptpn? Terbang dong bang, salam kenal bang saya anggota baru di CAM
- DeVIN
- Master Sergeant
Re: video tutor
Salam kenal juga bang.
Retired bang,... long term, maybe.
Tapi tuk fun flyer bolehlah, bawa si Petak tuk hover2 aja. Diusahakan.
Salam.
Salam.
- davidsgrt
Re: video tutor
@oom Devin
wah thank you ya oom
, ntar dicoba deh...
kalo ga bisa
tolong diajarin ya oom
kalo ga bisa
- BERTHIE FLYER
- Master Sergeant
Re: video tutor
wah keren tuh pesnya bang,,, segera dimaidenkan lah bang
- DeVIN
- Master Sergeant
Re: video tutor
He3x, udah jungkir balik bang,....
Gak ada lagi yang dimaidenkan,.....
beritanya disini,...
http://spadworld.net/forum/viewtopic.php?t=15697
Gragers go international,....he3x.
Salam.
Salam.
