Ducted fan powered dengan prop powered
Moderator: unding
Arsya9612
Re: Ducted fan powered dengan prop powered
Post by Arsya9612 »
Oh ya om
apa boleh menggunakan motor Edf ini (katanya max=22.7a loaded full throttle)
dgn esc 20 a,
Pertama... Turnigy 2610 EDF Outrunner 4000kv for 55/64mm
Specs:
Kv- 4000
Dimensions: 47 x 26mm
Shaft: 2.3/3.0/3.175mm
Voltage: 11.1V
Weight: 51g
No-load current: 1.4A
No-load RPM: 44440
Load current: 22.7A
Load RPM: 34480
Thrust: 560g
Kedua .....Turnigy 2810 EDF Outrunner 3800kv for 55/64mm
Specs:
Kv- 3800
Dimensions: 46 x 28mm
Voltage: 11.1V
Weight: 59g
No-load current: 1.9A
No-load RPM: 43480
Load current: 21.8A
Load RPM: 35080
Thrust: 535g
Dipadukan dengan EDF UNIT ini...
Atau menggunakan impeller ini...
bantu ya....
Return to “Electric Power”
