wd 500
Room khusus fans berat WD
dulbehek
wd 500
Post by dulbehek »
http://www.bananahobby.com/2331.html
he he he he ternyata ada kelas baru dari wd setelah
wd 300 muncul wd 500
Banana Hobby » 4-CH 3D Aerobatic RC Planes » 4CH 2.4GHz Art-Tech Giant Wing Dragon 500 Radio Remote Control Electric RC Airplane Glider RTF
Perfect for Beginner 4CH 2.4GHz Art-Tech Giant Wing Dragon 500 Radio Remote Control Electric RC Airplane Glider RTF w/ 55" Wingspan + EPO Durability + Optional FPV Camera System
Item No: 2331
Estimate Ship Date: Mid June, 2012
Price: $179.90
Preorder:
Camera System:
Extra Battery:
Battery for Transmitter:
Safety Option:
Neck Strap:
Feature:
4 Channel Full Function Radio Controlled (Aileron,Elevator,Rudder,Throttle)
New 2.4GHz spectrum technology, with the functions of automatic identification and precise code pairing, strong anti-jamming, and allow more than 20 aircrafts to fly at the same field at same time
Full aerobatic characteristics; inside loops, outside loops,axial rolls, inverted flight, knife edge, stall turns,hammerheads, and spins are possible
Powered by reliable state-of-the-art professional Outrunner Brushless Motor, Brushless Speed Controller, and 1300mAh 25C 11.1 Volt Li-Po Battery Pack
Super easy to assemble/disassemble(no glue required), change battery, and maintenances
Optional High Quality 4GB 640x480 First Person View (FPV) Camera System *Sold Separately
Perfect for beginners flying RC model airplanes for the very first time!
Fly steadily and operate easily, beginners can master the flying skills in short time
Ready to Fly in Just Minutes!
Molded plastic fuselage for super strong airframe and durability!
Super tough, lightweight, crash-resistant EPO main wings and tail wings!
Perfect appearance and emulation (Scale appearance, great attention has been given to details)
Shock Resistant Reinforced fuselage and Strong Wings
Excellent Flight Performance
Fuselage with pre-installed electronics
Crash Resistant Construction
Easy to Fly, Easy to Control, Super stable for beginner
Approximately 30 minutes flight time on each charge -- Optional Li- poly battery will help to achieve better performance and longer flight time
All spare parts and accessories are available
Complete Kit, Ready to Fly, Easy to Assemble (Everything is included and 90% assembled -- only required AA batteries for the transmitter)
Specification:
Wingspan: 1400mm (55.1 inch)
Length: 995mm (39.2 inch)
Flying Weight: 1075g (37.9 oz)
Speed Controller: 20amp brushless ESC
Servo: 4X 9g high speed micro servos
Battery: 11.1V 1300mAh 25C Li-Po
Control System: 2.4GHz Multifunctional Transmitter and Receiver
Radio Control Range: 3000 feet (1000m)
Package Include:
Airplane (95% assembled)
4 Channel 2.4GHz Multifunctional Spectrum Transmitter
Battery Balance Charger w/ Wall Adaptor
High Quality Rechargeable 11.1V 1300mAh 25C Li-Po Battery
Pilot Figure
Optional High Quality 4GB 640x480 First Person View (FPV) Camera System (NOT INCLUDED)
Instruction Manual
he he he rencana nya landing gear system nya di tiru di wd 400 class atau wd kuning yang ada dipasaran
fidaero94
GUEST
Re: wd 500
Post by fidaero94 »
wih mantep om dul... ga heli aja yg punya seri 500 ternyata wd jg hhihihi
dulbehek
Re: wd 500
Post by dulbehek »
semua seharuse ada serine deh,
seri itu kan nunjukin panjang nye fuselage
orchiplane
Re: wd 500
Post by orchiplane »
WD berevolusi... :aji :plk
cuman Esc bawaan nya spt nya gampang panas ya om.. sm batre kuecil menopang beban 1kg.. :pyg kesedot bentaran abis daah...kan spek buat fpv... :flu kalo newbie ada yg salah mohon dihatur maafken... :pis
doditsky
Re: wd 500
Post by doditsky »
big wd...makin anteng...ayo HS lokal.....kayaknya belum ada cerita nggak laku jualan wd....ayo buruannnn
fidaero94
GUEST
Re: wd 500
Post by fidaero94 »
dulbehek wrote:semua seharuse ada serine deh,
berarti tu seri WD 500 pjg fuselage e 55" wih knapa ndak WD 550 aja ya hahaha
jadi sama kaayak trex 550 :mwr
farhanalfarisi
Re: wd 500
Post by farhanalfarisi »
Wahh ,makin Gede makin stabil , hehehe . aku aja nerbangin wd V2 Belum Lulus :wek :wek :plk :plk
Nyampe Indo berapa tuh ? :shy
dulbehek
Re: wd 500
Post by dulbehek »
yang jelas penyakit LG letoy bisa sembuh deh klo kita terapin di wd 400.tapi jangan hard landing klo ga pengen batrenya jebol ke tembus lg depan
wanwan
Re: wd 500
Post by wanwan »
WD semakin mantab aja...dan...NGGA ADA MATINYA... :mwr
Re: wd 500
agak misleading sih itu description nya Banana Hobby, masa wd dikata 3D model #-o , walau om suhu Budi bisa hoverin WD :mwr
