real flight g4, siapa yang udah pake????
Moderator: DeVIN
aik-art18
GUEST
Post by aik-art18 »
Mod-edit,....jangan ada e******r-nya ya om,.... copyrighted.
PAMER AH!!!!!
setelah 2 hari mendonlot akhirnya selesai juga,
ternyata g4 dengan g3.5 hampir tidak ada bedanya. yang beda tentu hanya tampilan dan airpotnya saja.
udah ada e******r-nya lagi.
ini gambarnya.
wah, file Size berapa Mb?
aik-art18
GUEST
Post by aik-art18 »
2,5 GB
DeVIN
Post by DeVIN »
Ini yang bikin beda,..........
Kutipannya disini,...
"When i first opend the box i found everything nicely packed and colorful , As i pulled out all the foam i found this beautiful Interlink ELITE. Here's the awsome part, it looked and felt like a real radio! It wasn't thin and "boxy" like the Interlink PLUS. After holding my eye candy i continued looking in the box, and what do you know i pulled out the CD case . The case was very nice, it was like you're average DVD case except it held four colorful RF CD's, and yes G4 came with trainer cables.
After installing G4 i found myself at the launcher, and boy was it nice with the Electrifly PBY Catalina and the 3D feild "Alpine Lake" in the backround. After it was done loading the airport i just said "WOW!", i could not beleive the high quality and resolution of the Photofeild "Evergreen Airport"! After looking around i found that the Extra 300L is the stock aircraft (wich looked awsome), i also noticed that RF configures the sims graphical settings to get the highest possible performance without it running with low FPS.
After flying around for a little bit with the extra, i found the following new features:
- Prop reflection caused by the sun hitting the prop.
- Springy shock absorbing landing gear.
- Improved ground handling over G3.5
- The console feature
- The Interlink ELITE allows you to choose aircraft, airports, radio guid ect. without even touching the mouse.
- More features in the aircraft/airport editor.
- And a new chat bar and navigation guid.
Ups:
- Many new features, updated aircraft 3D models.
- New places to fly.
- New aircraft/airport feautes.
- Float Flying
-Helicopter rotor head animation updated
Downs:
-Unexpected error is still received.
-Currently you will experience errors while editing an airport for a long period of time.
- Flight physics are the same as in G3.5."
versi resminya:
RealFlight G4 adds a number of often requested features, including:
- New aircraft
- New airports
- Float flying
- Better sailplane support, including a variometer, better thermal support, and dynamic soaring
- A completely redesigned controller, the Interlink Elite, based on the Futaba 6EX, with digital trims and built-in navigation buttons
- A console system allowing low-level commands and bindable keys.
- More realistic ground handling, including springy landing gear.
- Many, many user-interface and general usability improvements. For example, it is now possible to import multiple swap page items at once.
- New rendering features, including a "bloom" post-process effect, soft shadowing, new prop and heli blade effects. Also, more ways to tune the quality/performance trade-off to your liking.
Current customers of RealFlight G3.5 will receive a rebate toward a purchase of RealFlight G4. Our publisher, Great Planes, will announce pricing and the rebate details shortly.
One important note: RealFlight G4 is not compatible with the RealFlight Classic or G2 "Add Ons" packs. It is, however, compatible with all RealFlight G3 Expansion Packs. Unfortunately, the older Add Ons just couldn't be reworked to fit into G4's way of doing things. We are still looking into some way of making these packs available to RealFlight G4 customers.
Salam.
wah 2,5 gb?
abis memori ku!!
DeVIN
Post by DeVIN »
Redblur wrote:wah 2,5 gb?
abis memori ku!!
bandwith blur,...bukan memori,.... so beli di DVD aja,..PM om CC_devil tuh.
Salam.
Jadi program nya berapa MB om?
soalnya sisa di Komputer cuman 1 gb
btw om aik-art
pakai dongle apa?
katanya donlod?
DeVIN
Post by DeVIN »
Redblur wrote:Jadi program nya berapa MB om?
btw om aik-art
pakai dongle apa?
katanya donlod?
Ini pake e******r blur, un-dongle (bisa kabel mic),... jadi pake PM aja kalo mo nanya ya blur,....copyrighted material.
Ok ya blur,...btw sisa 1 gb di hardisk kompi,....weleh apa gak kasian tuh blur kompi lu,...ntar aku tunggu kabar meledak kompi-nya ya blur, kasian kompinya.
Pastinya ya besar blur,..setelah dikembangin,.. donlot model lengkap, variasi,...aku pake g3,5 lengkap ep1,2,3 model2, semua sampe 6gb, dan g4 sampe 3 gb.
Salam.
aik-art18
GUEST
Post by aik-art18 »
seperti g3.5, tinggal colok aja yang berbau joystik udah bisa.
ooh pake e u a t * r.
kalau crash ada efek khusus gak?
apa cuman nancep gitu?
