Auto shootter Kodak yg dikendalikan dg remote control
Forum rules
thoha
Post by thoha »
berikut ini kode untuk kamera auto shootter yg dikendalikan dengan remote control
saat ini sudah saya pakai di kamera Kodak CX7430
secara teory juga bisa diterapkan pada semua merek kamera
sebelumnya saya ucapkan terima kasih kepada pak Jeny
atas bantuannya
Code: Select all
This program was produced by the
CodeWizardAVR V1.25.7 beta 5 Standard
Automatic Program Generator
© Copyright 1998-2007 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project : kodak kamera auto shootter
Version : v2
Date    : 5/4/2010
Author  : Muhammad Thoha
Company : Seribubintang
Comments:
kodak kamera auto shootter ini dekendalikan dg RC pwm 1 - 2 mili detik
sinyal pwm 1.7 mili detik auto shootter aktif
sinyal pwm kurang dari 1.7 mili detik auto shootter tidak aktif
Chip type           : ATtiny2313
Clock frequency     : 8.003000 MHz
Memory model        : Tiny
External SRAM size  : 0
Data Stack size     : 32
#include <tiny2313.h>
#include <delay.h>
int timer1;
// Declare your global variables here
void main(void)
// Declare your local variables here
// Crystal Oscillator division factor: 1
#pragma optsize-
CLKPR=0x80;
CLKPR=0x00;
#ifdef _OPTIMIZE_SIZE_
#pragma optsize+
#endif
// Input/Output Ports initialization
// Port A initialization
// Func2=In Func1=In Func0=In
// State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTB=0x00;
DDRB=0x00;
// Port D initialization
// Func6=In Func5=In Func4=In Func3=In Func2=In Func1=Out Func0=Out
// State6=T State5=T State4=T State3=T State2=T State1=0 State0=0
PORTD=0x00;
DDRD=0x03;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0A output: Disconnected
// OC0B output: Disconnected
TCCR0A=0x00;
TCCR0B=0x00;
TCNT0=0x00;
OCR0A=0x00;
OCR0B=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// Interrupt on any change on pins PCINT0-7: Off
GIMSK=0x00;
MCUCR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// Universal Serial Interface initialization
// Mode: Disabled
// Clock source: Register & Counter=no clk.
// USI Counter Overflow Interrupt: Off
USICR=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
#asm("sei")
PORTD.0=0;
PORTD.1=0;
PORTD.2=0;
PORTD.3=1;
DDRD.0=0;
DDRD.1=0;
DDRD.2=0;
DDRD.3=0;
while (1)
while (!PIND.3){;}
timer1=0;
while (PIND.3){timer1++;delay_us(1);}
if (timer1>700)
      PORTD.2=1; //LED on = shooter aktif
      PORTD.0=1; //fokus off
      PORTD.1=1; //shoot off
      delay_ms(3000);
      PORTD.0=0; //fokus on
      delay_ms(1000);
      PORTD.1=0; //shoot on
      delay_ms(1500);
      PORTD.2=0; //LED off = shooter tidak aktif
skema menyusul
Abi Ghiffa
Re: Auto shootter Kodak yg dikendalikan dg remote control
Post by Abi Ghiffa »
Mantap om,...ditungguin skemanya ya.
didin
Post by didin »
ini dia "OPEN SOURCE" yang ditunggu-tunggu....
Trims pak Thoha....
thoha
Post by thoha »
Abi Ghiffa wrote:Mantap om,...ditungguin skemanya ya.
ok mas
skema masih mirip yg ini
cuma ada tambahan LED dan input PPM saja
bagi yg sudah terbiasa kayaknya nggak perlu skema lagi
sudah bisa menggunakan
didin wrote:ini dia "OPEN SOURCE" yang ditunggu-tunggu....
Trims pak Thoha....
iya pak
saya lagi mencoba merintis OPEN SOURCE
sebagaimana banyak dilakukan oleh teman2 kita yang lain
rachmatjeny
Post by rachmatjeny »
selamat pak thoha =D> =D> =D>
selanjutanya tinggal mixing quadcopter...
enak TOH \:D/ \:D/
thoha
Post by thoha »
rachmatjeny wrote:selamat pak thoha =D> =D> =D>
enak TOH \:D/ \:D/
makasih pak
code ppm timernya matab
dicoba langsung maknyus...
saya lagi bikin mixer 4 input dan 4 output
dengan sensor accelerometer
fungsinya untuk position hold pada heli
supaya tidak ngeloyor ke mana2
jadi bisa hands off
KBSantoso
Post by KBSantoso »
Tambah salut sama paka Thoha nih.....
Top...... =D> =D> =D>
thoha
Post by thoha »
KBSantoso wrote:Tambah salut sama paka Thoha nih.....
terima kasih mas
bagi yg ingin membuat sendiri
berikut ini skema lengkapnya
sebenarnya ide ini bermula dari produk ini
detcord
Post by detcord »
terima kasih mas
Belum Ngerti Pak, maksudnya alat ini bisa mencet tombol kamera sendiri ya? tolong penjelasannya lagi.. makasih
davit123
Post by davit123 »
terima kasih mas
mau dong
