Kim-Edge
membahas pesawat gepeng
Moderators: su-31, Budi
su-31
Kim-Edge
Post by su-31 »
Prelude to a Hov..., Beldili !
Ini sahabat sy, A-Kim, yg ngajarin saya RC di awal thn 80.
Puluhan taun gak ketemu, dia terkesima liat saya hover..., PLANKER kelas .40
su-31
Re: Kim-Edge
Post by su-31 »
su-31 wrote: PLANKER kelas .40
Planker strikes back ?
:-k ...enggak juga sih,
Singkat cerita dia minta dibikin Planker gede !
Gara2 liat saya dan ini...
Abdinik
Re: Kim-Edge
Post by Abdinik »
tahu '80 an para master suhu dah main pesawat gaban...
saya belum lahir suhu... :thx :thx :thx
su-31
Re: Kim-Edge
Post by su-31 »
O iya, itu dia minta dibikinin taun 2010... ! :-$
Maka sy mulai dengan ini, coret2 dulu,
...ngitung2,
Target Prototype:
Wing span.....62 in.
Length..........61.5 in.
Wing areaÉÉ.1059 sq. in.
Flying wt. approx. 6.4/6.9 lb. (2900/3400 gr)
Engine...2C .61-.91 or 4C .91 - 1.10
Max WL= 16.2oz/Sq-Ft (49g/Sq-Dm)
Barebone + Cover = 1840gr
Actual:
Wing span..........64.4 in.
Length.............61.5 in.
Wing area...........1007 sq. in.
Flying wt. approx. 6.4/6.9 lb. (2900/3200 gr)
AUW = 3320gr
su-31
Re: Kim-Edge
Post by su-31 »
Potong2 RIB, balsa stick, Plywood dll.
oops, kami datang dari teknologi masa lalu..., gak ada Laser Cut, Die Cut.., modal cutter aja.
Bangun sayap...,
Itu carbon buat Jig sementara aja.
su-31
Re: Kim-Edge
Post by su-31 »
Dan LE sheeting nya pun cuma pake tali rafia aja !..., gak ada alat press segala.
su-31
Re: Kim-Edge
Post by su-31 »
...trus Fuselage nya, kurang lebih kayak gini lah,
su-31
Re: Kim-Edge
Post by su-31 »
Tail Section,
Ngukur incidence..., pake laser guide pinjem PToto punya !
su-31
Re: Kim-Edge
Post by su-31 »
Power plant nya dikasi OS .91 4Stroke Surpass, generasi pertama.
Ya asli OS Made in Japan !.
A-Kim sahabatku ini asli anak China, tapi gak pernah mau pake engine buatan China !
(awas kualat loh Kim !).
Re: Kim-Edge
su-31 wrote:Dan LE sheeting nya pun cuma pake tali rafia aja !..., gak ada alat press segala.
sederhana, berguna, gak terpikirkan oleh orang lain ... :plk
