ini video nya hasil penelusuran dari youtube
Feature
The DEVO F7 adopts 2.4 GHz Direct Sequence Spread Spectrum (DSSS) technology and features automatic ID binding and ID assignment. It can also be customizedly set as fixed ID code
5.8G real time image transmittion
USB online update makes you always enjoy the latest firmware
Adjustability of hi-frequency output power enjoys more personality and friendly environment
Wireless data transmission between two DEVO F7 helps experience the training function
Up to 15-model data can be saved
DEVO F7 adjusting the gyro sensitivity makes hovering flight and fancy flight in an easy way
Super large LCD display features direct and convenient setting
Shape design accords with human engineering and provides comfortable holding
Both the length and tension of the sticks can be adjustable
DEVO F7 can be freely switched among Modes 1, 2,3 and 4
DEVO F7 support Helicopter and Airplane.
The Helicopter mode provides three flight modes, each of which can be freely set and its parameters can be personalizedly adjusted to meet the requirement for F3C or 3D aerobatic flight
Specification:
Encoder: 7-channel micro computer system
Frequency: 2.4GHz DSSS
Output power: ?100mW
Current drain: ?500mA (100mWh)
Transmitter power supply: 7.4V 800mAh
Output pulse: 1000 - 2000Ms (1500 Neutral)
Image receiving: 5.8G
Channel selection: 8 channels
Ini Rx nya
DEVO RX701 Specification:
Type: 2.4GHz 7 channels
Sensitivity: -105dbm
Frequency interval: ?4M
Receiver battery: 4.8-6V 1300mAh
Weight: 11.6g
Dimension: 43*28*16mm
Ini modul kameranya
DV04 Specification:
Pixel: 200 Mega pixel
Definition: 420TVL
Storage card: Micro SD
Working voltage: 5V - 8V
Resolution ratio: 1280*720
Color: Color
Working temperature: -40°C - +85°C
System: PAL / NTSC
White balance: Auto
Weight: 14g
Dimension: 44*36*10mm
ini modul Tx gambar and vidio
TX5803 Specification:
Power: 200mW
Channel quantity: 4
Channel: 2 / 4 / 6 / 8
Image range: 300m
Voltage: 7.4V or 11.1V Li-Po
Helicopter class: 200 class or above
ini beberapa photo yg terekam
perbandingan ama devo 10 ane yang di lahirkan dari pabrik yg sama
