FYI: Update terakhir Reflex HANYA sampai versi 5.03,.....
Moderator: DeVIN
DeVIN
Post by DeVIN »
Info: update terakhir reflex dengan dongle yang ada sekarang ini hanya sampai versi 5.03,... untuk versi berikutnya 5.04 hanya bisa dengan control Tx yang baru; iVol, atau dengan mengganti dongle dengan dongle yang baru (dongle lama tidak bisa dipakai),...
see, http://www.reflex-sim.de/reflex-sim/sho ... faqPath=20 tuk Reflex 5.04+iVol
see, http://www.reflex-sim.de/reflex-sim/sho ... ath=20_149 tuk dongle yang baru
Sedih,...
Salam.
DeVIN
Post by DeVIN »
"We do this in order to safe a lot of costs for software copy protection and in order to avoid illegal software copying. Reflex upgrades are NO FREEWARE and it is not FREE OF CHARGE! We give it to you without costs and payment is your free decision.
Certainly, we reserve the right to change this policy if needed. The today's copy protection is linked to the interface and the interface coding. We reserve to right to change the interface coding in later software version if we have to find out that the interface will be illegally copied. In that case, we consider publishing the personal data of the people in charge.
Because of that, we don't allow Reflex upgrades to be sold by anybody at eBay or similar market places."
see, http://www.reflex-sim.de/reflex-sim/sho ... Path=20_76
Apakah ini berarti upgrade setelah v5.04 - pun, harus langsung dari pabriknya (tidak akan dijual dimanapun; apalagi didonlot), dan terjadi kontradiktif yang membingungungkan antara "NO FREEWARE and it is not FREE OF CHARGE!" dengan "We give it to you without costs and payment is your free decision."
dan, mengutip http://www.rcgroups.com/forums/showthread.php?t=728909, post 2
"New Slimstick USB 79.00EUR
The new slimstick USB interface is campatible to the new iVol technology and can be used as a joystick as well. This way it can be used with all kinds of games using a joystick input like Microsoft Flightsimulator, X-Planes and many more.
The order will be executed only after receipt of your old interface. We only need the interface. No invoices, no cables, no CD's. Please select the cable you need to connect your radio As before you can get additional cables if you need them and they just plug into the back of the slimstick interface.
[b]The new slimstick interface will work with Reflex XTR version 5.04 or later and it will not work with earlier versions. Future Reflex XTR versions will be compatible to this new interface only.
In detail: You are mailing us your old Reflex XTR interface and tell us what radio connection your need. We are shipping the new slimstick interface, the cable to suit your radio and the CD containing the latest Reflex XTR Software 5.04 or later."[/b]
79 EUR=rp. 1jt, .....ehm,. .....ternyata masih ada harapan dongle yang lama kalo dikirim ke mereka dapat diganti dengan yang baru,...
tapi apakah dongle yang kita pake sekarang asli????
Salam.
DeVIN
Post by DeVIN »
Dan akhirnya, harganya kembali melunjak menjadi 225 EUR, ato menjadi sekitar Rp. 3jt,...... (try google, first)
Hi3x,....... ikutan Phoenix dan realflight sepertinya, menjadi gak "murahan" lagi.
Salam.
Waduh... sudah kecium ya...
Wah, kalau mau yang original jelas nggak bakal kebeli.
AgoesAurelz
Post by AgoesAurelz »
Kira-kira versi Reflex terbaru masih ada pagar merah nyebelin ga ya?
kalo masih ada, mendingan maen Phoenix-Sim aja deh....
hadi
Post by hadi »
ayo pak, pake phoenix lebih asyik tuh, heheh...
NVY
Post by NVY »
Jadi Simulator yang paling mendekati kondisi aslinya yang mana Pak ?
Ya untuk pesawat...ya untuk heli...
dion
Post by dion »
sudja'i sarmo wrote:Wah, kalau mau yang original jelas nggak bakal kebeli.
Kalo beli ga original ada yah pak de... dimana bisa dapet yah :)
