ada referensi bagus nih, semoga bermanfaat
http://www.airfieldmodels.com/informati ... design.htm
Introduction to Radio Control Model Aircraft Design
Moderator: coyo
- phyque
- Master Sergeant
Re: Introduction to Radio Control Model Aircraft Design
sudah menuju TKP...keren euy
matur nuwun sanget
matur nuwun sanget
- Basuki
- trainee
thanks...suhu....
- fly123
Langsung ke tkp.
- Charles
Wah di tempatku gak bisa dibuka..apaan sih ???
Charles wrote:Wah di tempatku gak bisa dibuka..apaan sih ???
Garis besarnya ke arah ini pak :
(Utk pak Charless rasanya sih udah biasa pake metode ini )
If you are building a model primarily for flying characteristics, then that is what you design around.
Purpose of the model
Style — Modern, Old Timer, Scale, Sleek, etc.
Powerplant class
Flight time
Stability — Should the model be self-stabilizing, neutrally stable or somewhere in between?
Airspeed envelope
Vertical performance
Control response
Stall characteristics
Construction methods — Traditional wood, composite, etc.
Control system
Landing gear system
Break-down for transportation
Etc.
